Lets See Those 16's Please!!!
one things i dont want to do it rub, it will just annoy me. i got time to keep looking for the right size. i think i did find a set of wheels that had a 48 offset in a 16x7
im really liking these wheels....16x7 with a 48 offset and only $170 each
hopefully these will be available when im ready to buy
Link.
205/50s on +42 is definitely a gray area. I'm running 205/50s on +40, I rolled the fenders, and I'm still rubbing. But my tires' section width is unusually large. More normal 205/50s might squeeze right in there. :)
so they would rub on the fender or on the fender lining? I just don't want them to be rubbing on the shocks.
i think those are the wheels on a white pro5 and i think it looks good. those are what im getting!!! 16's too for performace.
^^^ Those look like 17s and I don't think they are 5Zigens either. Maybe Gram Lites even?
*EDIT: No, I think you're right, just 17x7s
well whatever they are i like the look. if his are 17's i think 16's would still look good. idk why im looking for rims again right now anyways, its fall and im not buying until after winter so i got time to make up my mind.
k, thanks. i'm pokin around for 16s, 12lbs if possible
well if you got money to spend, look at the gram lites! they are light
Oh yeah, I definitely agree. I was originally going to try to go for the 5Zigens in 16x7 but the only offset I could find for that size was +42 which I think would be a little tight. I ended up seeing some Gram Lites 57c which look very similar but have an offset of +46. Couple those with some 225/45 rubber... mmm, can't wait. Need to save some money.
I'm so sick of these MSP wheels...
i wish i had baught 45 series tires, but i baught 205/50/16?? i think i might call discount tire and see if they can change it? They should since its been a month and they havent shipped my wheels and tires yet!
I want to pull the trigger on some Enkei RPF1's 16x7 +43mm for my P5 on Espelirs. Rishie's fitment guide doesn't make mention of 16's and I'm curious if 205/50/16's will fit. 215/45/16's? I'd really hate to roll the fenders :/
I have 16X7 rota's with an offset of 45 running 205/50/16. The drivers rear rubbed under load and had to roll that fender. I would say that enkei's will rub even more and possibly on other corners as well.
I was grabbing at straws since I'd read everywhere that +42mm were close and was hoping the +43mm would be just enough. I really like the thought of the 16's, but I guess I will just rock the 17x7.5 +48mm.
