canadianexpress
- Mazda5, Acura 1.6EL
Would an alignment be necessary after changing the struts on the Mazda5?
Thanks
Thanks
I'd say yes to the front, no to the rear.
Huh. I would tend to disagree.
We just installed MS3 springs on our M5. The front alignment cannot be changed unless you mess with the steering rack. Don't change the end links - and the car should track straight.
And the rear, just make sure you adjusted the rear toe on the trailing A arms (two 17mm) and you should be fine.
Once I'm done messing around, I'll get it aligned - but after a spring install, it drives straight, tracks straight, and no pulling...
m.
