Installed the AWR front mount...
ho bag
2007 Mazda5 GT
Well to anyone that says is vibrates to much....it doesnt.
I installed the 95 duro front mount and sure at idle it vibrates a little bit but not even enuf to rattle the change in the cup holder, and as soon as u touch the gas it stops. While driving there are no extra vibrations at all!
Also the car feels just like stock to drive until you try and shift like an asshole and then you see why the awr mount is in there :D
All in all, get the awr front motor mount, you wont regret it :)
Some nights mine shakes really bad others not so bad, but I've had the mount over a year and its shakes enough to not get used to it.
you sure it wasn't a 70? I have a 70 in and it vibrates enough to be noticeable, but not enough to rattle change...
Bill,
What tool did you use to remove the stock motor mount inserts from the metal bracket on the passenger side. That 1 is giving me a hard time.
When I had my OBX header on, My car would vibrate really bad after I installed the motor mount, but when I put the turbo in, it all quieted down. Virtually no vibration now.
I have front and rear (you notice the big difference when you replace the (probably) broken) mount.
The vibes have settled somewhat - but i have also spent a lot of time chasing buzzes and rattles(which bother me probably more than other people).
It is all-in-all a good mod for the wheelhop issue. If i didn't have wheelhop - i would not have done upgraded mounts. Quiet is Good.
BIGANT said:
Bill,
You don't remove them. You insert the inserts into the side mounts and then use zip-ties to hold them in place.
Front & rear are complete motormounts.
i hear the rear mount is what makes all the vibs, I deffently liek my front and i wont upgrade any others. I happy with just the front
i have the front motor mount, and inserts all around, one of my mounts is bad but the vibrations aren't that bad at all
and the reward is well worth it
I thought this too. Then my other mounts wore out and I began to feel the engine rocking around again.
Thanks for the reply.
With front & rear 70's, at idle, my front license plate rattled more from those mounts than my trunk ever did with 2x12's.
It's not a Harley, and I sit in traffic a lot, so back to stock I went and never looked back.
My solution to wheel-hop? SLOW DOWN!
My solution to wheel-hop? SPEED UP!
good thing i double checked that, i thought i read it wrong ;)
Okay, are you all talking about the problem I'm having with my '02 P5 and that's when I'm just starting out in first and if I am giving it a certain amount of gas to clutch the passenger side makes a clunk clunk clunk noise, is that a mount of some sort? if not sorry to post in this thread
Cheers
Pea
Cheers
Pea
Yes, when you're in first and the car feels like it's jerking back and forth (can be quite violently).
