How To: Air/Fuel Ratio Gauge Install
well as u haave seem in the pics i don't have any wire with foil going to my ecu so (shrug) duno what to do and ther is no o2 sensor for sure the problem is that my car in no american version it is a japanes one so would that be de problem??? but it doesn't have any o2 sensor for sure i looked and nothing,i also wanna know the air fuel ratio gauge how does it light up starting from one side green light right? and when the car is just on the first green light stays lighted just one led or should it turn on more leds?!?!??!?!
Brian MP5T said:
60 Has Foil on the wire...
Hey !!!
well i connected to where the pics show and it is working great !!!
dominoy2k1 said:
it should show numbers on the ends of the wiring harness. . it should be like 1-40,41-80/81-120. something like that. check the picture.
mine just jumps from side to side very distracting, is this right. just want to change gauge to water temp or something
old post but here is some more information. i know a lot of people had to ask where to get their constant 12v source from when the car is turned on. the best place to get constant 12v source from only when the car is on is from the ignition wire in the ignition harness. if anyone wants wire colors, check below. also, i have not done this yet though i plan on it and was wondering if anyone knows a good pillar pod that has spots for two gauges. i am not a fan of the autometer ones as they are black and just cover the existing a-pillar plastic it looks likes. i want a complete replacement. thanks in advance
protege 5 wiring
- ignition - 12v + when vehicle is on - blue
I installed mine today! : ) It does jump until the car warms up and then gets used to the ECU adjusting, then it kind of calms down.
Only complaint: No backlight! Oh well. Maybe I will take it apart sometime when I get really bored and attempt to add one! : ) Hee hee
I installed my A/F guage today. I spliced into the Pink wire w/ blue stripe at the first O2 sensor and my guage jumps back and forth when i'm at idle. I just read into the thread about splicing into the second O2 sensor for a steadier reading so I will be doing that tomorrow. Hopefully it will keep it from jumping around so much. Also have an DSM's AFC on order so we'll see if that calms it down a bit too.
Its supposed to do what it is doing. It is a narrow band that is the best place to put it. It doesnt give good readings. Just keep it there and save the trouble.
alright i just got mine in and i want to clear this up before i go and put it in. I got 3 wires; red, black, and purple. tell me if i got this right: red goes to 12v input, black to negative ground, and purple to sender? i'm going to tap into the pink with blue stripe wire from the 1st O2 sensor. if someone could clarrify it that would be great. thanks in advance.
edit* i also hear all these suggestions for a good ignition source for the 12v input. i planned on tapping into my cigarette lighter with my water temp gauge but is there any closer wires in all those harnesses in the drivers foot well?
so the cigarette lighter wouldn't work? i dont know what proper ignition cables are the right ones to tap into below the steering wheel. i'm also going to hook up the water temp gauge too, so is there a wire that could do both of those?
alright, pm me w/ your email address & I'll send you the instructions for installing a turbo timer. This has the instructions of how to get to & which wire is the one you would want. Once you find that you would just basically tap both wires into the same line.
