Gauge Works Full Pillar Pods are shipping
could someone give a howto on a water temp gauge and a volt gauge? broke my temp needle installing indiglo gauges and need a gauge to fix it
what size are the gauge holes for the gauge works pillar pod and where can i get a white face water temp gauge and a volt gauge?
52mm.
I'm in the process of painting mine now...I'll post pics when done.
Anyone know a good way to fasten the cover to the OEM a pillar cover?
I used 3/4" peal'n'stick Velcro tape. The only trick is the cover and the original pod only touch at certain places so you have to find one (or more) of those places to put the tape or you won't get a good hold. Good luck!
What kind of paint are you using to match the interior? This is a full replacement pilllar right?
paulmp3--Here's my earlier post on paint for the Full Pillar Pod cover:
Here's what I've found out about painting the black Gauge Works Full Pillar Pod.
Mazda only sells exterior paint so no help there.
I pulled the passenger side A pillar (not a hard job--start at the top and pull straight out, then work back and forth the molded guide at the bottom). Looking at it in bright light it is evident the color (light gray on mine) is actually molded in and has some black flecks so no paint is going to match perfectly. I went to Home Depot so I could get the color scanned to match and here's the formula they came up with: Behr Premium Plus Int Satin Enamel, Pastel Base (7500) with the following colarants: B Lamp Black, OZ-0,48-10, 96-0; E Thalo Blue OZ-0,48-2, 96-0; L Raw Umber OZ-1,48-28, 96-0.
The color matches pretty well but clearly will look different from the other pillars on really close inspection as the new paint isn't molded in and doesn't have the flecks. The unpainted surface does have a slight texture like the factory pillars and all-in-all I'm happy with the paint.
This is latex paint so it's easy to clean up. It comes in flat, eggshell, satin, gloss and high gloss (from no to high sheen). I chose satin but believe flat would match better. Cost is $10/quart (the smallest custom match size) which will allow you to paint about 10000 pillar posts.
Full pillar pod cover picture
Finally got a digital snap of my installed Auto Meter Full Pillar Pod Cover with Nordskog digital gauges. The top is the boost gauge and the bottom is the air temp (for under hood ambient temp) gauge.
hrm.. okay here's my question what all do i really need guages for and do they really help me any, im sorry i dont know much i just drive the thing. would it be enuf just to know the psi the turbo is kicking out? or could someone tell me the three most common guages found cuz if i do it i wanna do a tripple pod cuz the others just dont look right with a single or dual.
If you have the Mazdaspeed, you at least need to have a boost gauge. I don't know what the hell Mazda was thinking by not including one. :wtf:
i would think, Boost, Air/Fuel ratio, and Voltage are probably the most common... but thats just a guess...
