The primary problem with running bigger injectors on the stock ecu is that whenever you increase the size of the injectors by more than 10% you destroy the driveability of the car (poor idle ect). Since you have increased fueling and are unable to trim fuel out like at idle where you do not need extra fuel your car will drive like ass. As far as fuel pumps go, its not a bad idea to upgrade and inline fuel pumps are just fine such as MSD, vortech and walboro to name a few. If you want the best pump money can buy bosch would have to take top honors
Our plug n play pre-tuned system will allow for 10psi operation and it's recommended to get an additional inline so that the stock pump does not get maxed out.
