Forge BOV Setup Questions...
FL_Speed001
1993 Mazda Miata B&T
Been on the forums for a while, spent most of my time reading and learning.
I just bought the Forge BOV for my car, and spent some time searching old posts looking for pics of someone elses setup. Most of the threads I did find no longer had working pics. I was hoping someone could post some pics of their install (I am otherwise stock). I want to make sure I tap into the best boost/vaccum source for the BOV, and not screw anything up.
Thanks in advance for your help, and sorry for the noob question! (help)
tap the line that goes into the top of the manifold, if you have more ?'s pm me i'll send you some pics, easy install you'll love the Forge
Here you go:
If you have any more questions or need more instructions on what i did, just send me a PM. Ill help you out.
Chad
Thanks for the help...what size "Ts" did you use for the brake booster line? (I have the Forge connected now using stock bypass line...what is the best way to cap this off if I go w/ the brake booster line?)
Thanks again for the help!
