Floor Jacking Points on the 5
switz
2008 Mazda5 GT 5-spd manual
I tried to use the search part of this website but all that happened was that I found stuff not related to the 5 and when I did search the 5 location it timmed out. Grrr.
So here's my question, that's probably been answered before somewhere. What are the locations under the 5 to safely place a floor jack? I just purchased a floor jack today in preparation of the change-over to winter tires/wheels. I don't like using the jack that came with the car (well, acutually the jack is ok) or rather the locations where the jack is used along the side. The lower plastic skirt is getting warped from my twice a year tire change-over with my '08 5. I've never used a floor jack before and I'm pretty sure that I can't just start jacking anywhere under the car.
Garages have all different types of cars going in and being jacked up. Are there general reference points one can use to jack up any car. There must be because I can't see a mechanic trying to find a manual for a specific model of car just to find the jacking points.
Any tips would be muchly appreciated since I know the snow is coming soon :(
If I'm removing 1 wheel for non-suspension related work, I find that the attachment point where the lower control arm (LCA) meets the front crossmember is a good place. Or if you can get to it, the bottom of the lower ball joint. Basically the crossmembers are the best place for most wheel related work, like that post shows.
I actually don't understand how your side sill could get deformed from using the travel jack. I have two of them, and found that I could rotate my tires front to back very easily by jacking up 1 side at a time using the jack points under the car. The side sills never interfered...?
"f I'm removing 1 wheel for non-suspension related work, I find that the attachment point where the lower control arm (LCA) meets the front crossmember is a good place."
Same here. Perfect spot for a floor jack or jack stands.
