First 300 whp MS6
Insignificant said:
LOOK AT MY SIG. I will also be getting her tuned when the IC gets here.
add a test pipe, and tune and you will be in the 13.5 to 13.3 times most likelly!(nana)
4DRHTRD said:
Yeah, read my posts there guy.
I am an A type guy or I wouldn't be driven enough to be the FIRST guy STUPID enough to put a turbo kit on a car untested then drive to Texas to have an XEDE installed and then drive right back (like 7 hours sleep in 72 hours). Don't try and insult my intelligence, you can't even spell correctly most of the words in the quote above. I work out 7 days a week because I like to and because I'm the coach for my kid's wrestling team, also because I'm close to 40 and needed to drop some weight, don't hate. :P
Listen, you made a post acting like you were going to be in uncharted waters with the MS6, you're not. Do some searches on here and other MS6 forums and see what's out there before making bold claims of first to be 300 WHP.
Here's the dyno sheet you requested, posted in MANY of my topics in various places.
BTW, here's a cool video for you, of my car doing some 22 PSI redline pulls for ya....
http://www.azspeed6.com/movies/22-psi.wmv - right click save as.
Or faster download - http://putstuff.putfile.com/49623/7222439
Nice video!!!
jcgemt2003 said:
I bet you wont see even 5whp gain from that.(no)
Others have already dynoed I believe & saw gains. I won't be dynoing my car till my IC comes in & I won't be doing a ORP pull then a pull w/cat so I'll never know, but if you think yanking the cat does not net any gains, especially on a turbo car, you're just being silly.
this is very true, anything that frees up the flow is good for turbo, I felt a huge gain on mine even after removing the high flow
MS6mike said:
5 WHP is nothing? that lile 10 HP to the crank thats good even thou i think is more![/QUOTE
are you talking about the test pipe, 5 WHP is alot know?
I deffinatly wanna get it. but is it really loud?
i figured with out a cat it would be loud as hell hehehe, dont wanna attrackt cops thanks
im deff gonna get it.
this may sound like a stupid Q, but when u get all the bolt ons u can do for ur car does it also improve torque?
From what I've been researching test pipes for our cars don't seem very essential or give much in terms of gains....... i'd like to see someone gaining more than 5 whp from just a test pipe...... why not just get a turbo back exhaust and get more hp from that?
I can see what you mean, but to me 5hp to the wheels for such a low price mod, is worth it no?
low price mod? how much is a test pipe......under $100? I don't find that a low price mod......
I don't think it's worth it if you're going to end up getting a full exhaust in the future.......just a waste of money..... I'm just going to wait til i've saved for a full exhaust set up.
It's not only about the max HP that a mod gives you.
Just for argument sake let's say that you actually gain peak 5HP(I have no idea what is actually gained). That is measureable gain, but nothing to write home about. However you also have to ask yourself if you lost lowen end torque or if the 5 HP gain was all the way across the powerband. ect. ect.
My point is that peak HP is not the end all be all of going fast. It's about having a good usable TQ/HP spread across the whole RPM range. A 450 HP car can be faster than a 500 HP car depending on the HP to RPM spread.
You also have to consider that removing the cat and installing a test pipe helps the turbo spool up faster and that won't be measured on a dyno but it will help at the track.
That's true too, that's what I was trying to imply...... I find it kind of hard that a 5hp gain will be spread across your entire powerband....... on top of that......if you get the full exhaust setup for the car (which I some of the better more expensive "race inspired" exhausts remove the cat) then why the point of spending the money on the test pipe, when the money can go into the full spec exhaust? If I wasn't going to get an exhaust i might just end up getting the test pipe to spool it up faster....... although I'd like a turbo back dual exhaust..... and i don't think those come with a test pipe.....if that's the case then yeah i'd want the test pipe to spool the turbo up faster.......
does the test pipe put added stress/wear on the stock turbo?
when you say it causes it to spool up faster are you saying it takes a shorter amount of time for the turbo to start spooling (i.e. reduces turbo lag_.......or are you saying the turbo spools to a higher overall speed? (more boost?)
Reduces turbo lag, and makes the turbo's life easier. The test pipe reduces back pressure and allows the turbo to spin easier but it will still only reach the same speed (RPM) as before, it will just get there faster now.
The only way to increase boost is with a boost controller or tuner/piggyback.
just wanted to make sure so I wasn't misunderstanding........ anything that reduces turbo lag is a good thing (cabpatch)
thanks man.
