All i want is some very simple questions answered and ill be on my way.
Also i when i spool the turbo it has a constant loud whistle and it feels as if im developing little or no boost at all, but when i shift the compressor surge so loud it sounds like i was hitting 5grand. im pretty positive its a bad WGA diaphram since when i messed around with the wastegate the symptoms i just stated went away and all was normal again. But after a slightly hard pull from second it all came back. i just want to know if this sounds like a boost leak or overboost from a sticking WG (dont want to blow anything up)
ok before i get to doing anything i need to replace all my factory vacuum lines, anyone have some helpfull tips for removing them since they are all glued/clipped in? i know this may sound like a dumb question but i want advice to be sure. and what is a good source to buy vacuum hoses/clips?
last but not least... anyone know where to get an OEM replacement WGA, or an upgraded version?
I know i made a post before regarding the WGA problem but im more curious on what my symptoms are typical of, and i need to know where to get vacuum lines/clips just to go in and fix anything since i know none of the factory lines are going to come off in one piece (unless theres some special technique lol)
Thanks for any help...
