Exhaust too loud
twilightprotege said:
yeah shouldnt be difficult, but gee it certainly makes a difference!!!
You have this kind of muffler which has a separate silencer? Maeby you can take some pics? :)
i should add too, the silencer pipe is about 1.5" diameter i think...should add enough back pressure for low end power....well that's what i'm hoping considering i'm going a 2.5" system
pics of the silencer :
and yep, it's 1.5" inside diam, 15cm long
Sell your whole exhaust setup & buy someone's stock setup, then get a dump pipe/exhaust cutout...it's basically the best performance you can get when it's in use & sounds completely stock when it's not. Best part is they aren't expensive at all (if you still have your stock muffler & whatnot, you can get it done for under $400 installed [US $]).
No thanks!
I still have my stock setup, but the custom made is better, so cutout is not an option.
JustMe said:
No thanks!
Better than what? There is no way you are getting better performance than an exhaust cutout unless you are venting the exhaust gas straight out of the turbo.
Only one small problem, I don't have a turbo :P
