Driver's side arm rest removal.
My drivers armrest is stained and the only way to remove the cover is to unscrew the bolt. Thing is, that bad boy is on there tight. Anyone just Hulk that thing off?
Mine came out ok. get a longer wrench or use a pipe.
make sure you are unscrewing in the right direction (drive2)
Have you tried a breaker bar? Just make sure to get one with the proper drive size to fit your socket.
Spray a little Liquid Wrench on the bolt and let it sit for a half hour (or more) then go to town with your breaker bar and it should come right off.
