2017~2025 CX-5 Rear Liftgate Rattle
Los Gatos, CA
2021 CX5 GTR
I have this rattle on each side of my trunk hatch right above the taillights that rattles when the car idles and drives me crazy. Anyone have this and if so what was the solution?
That's a plastic trim that can be removed. Probably is missing some clips. If you have some plastic tool, you could try to gently remove it and you'll see how it's mounted and see if there are any clips missing. I've done some work on my car and had to remove this trim. There is a lot of dust and/or fine dirt accumulating under. A good opportunity for you to clean that area. Did you replace the back window recently? The trim must come off when they replace the back window and maybe the trim was not reinstalled properly.
Upvote 0
Upvote 0
I haven’t done any work on that back window or liftgate. The rattle started right after I bought the car and slowly is getting worse. It used to just be one side right above the taillight but now it’s on both sides. I was imaging some nut/bolt came loose but it looks like a bunch of plastic clips. Not sure I want to dismantle it without a clear solution. I think I’ll just try shoving some foam up there or something. Thanks for the info!
Upvote 0
Update: I removed all the plastic interior trim of the lift-gate in search of a loose nut/bolt and there was nothing there to be tightened. As ADS-B noted above it seems to be the exterior trim piece. I tried to peel it back a bit to take a look and seemed to have snapped a few plastic things. I put some double sided foam tape to stick it back together. Unfortunately the rattle lives on and possibly made it worse haha
Upvote 0
Get these: https://www.amazon.com (commissions earned) and https://www.amazon.com (commissions earned) .
Once you remove the trim, clean it and then apply the tape on the edges of the trim, both sides. You should be able to see where the tape is supposed to be applied. Most likely the trim is missing the tape or it's damaged.
Upvote 0
I do have those and some double sided decal tape. These are the plastic clips/plastic things that seemed to snap off, there was three of them. When you removed yours did you just peel it off from the outside of the car?
Upvote 0
Yes. What you see in the picture, that’s how it came off. You can also see the double side tape on the bottom left corner.
Upvote 0
If you look at this picture, the only holes are for the big inserts. Everything else is glued/double side tape.
Upvote 0
Ohh wow interesting. Ok, so what I think happened in my case - is the black plastic piece that is attached to the inside of the removable trim piece stayed attached to the car while I was peeling it back and it snapped off from their attachment points to the trim piece. And it seems the black plastic piece is part of the trim piece and is meant to stay connected to it ;( .. This gives me an idea that I will try when I get home. Thanks for all of the help/info, I will let you know how it goes.
I can't believe nobody else has had this problem!
Upvote 0
Mine has an intermittent rattle which definitely sounds like it's from inside the tailgate. I have never investigated it as it is not constant at all.
Upvote 0
I tried to shove some foam up there where the rattle is originating but didn't do much, and it also seemed to create a little gap where the rubber weather seal meets the back window..So I removed the foam lol.. How is that weather-seal/rubber gasket at the bottom of the back window looking after re-installing that back piece (still sitting flush with the window)?
Upvote 0
Sometimes sounds like a panel doesn’t mean it really from it. Have you try driving without the panel? To troubleshoot it is a pain. You have to remove part by part to know.
Upvote 0
Stil flush. I would try to use double side tape. Put some double side tape on the black plastic trim that rattles and redo the double side tape from the edges of the red trim, see previous pictures.
Upvote 0
I too have had this rattle for the past 60k miles after a dealer repair.
Been a bit nervous to take the panel off with all the clips holding it on. But I appreciate the photos, which better shows where they are.
Upvote 0
I found and fixed 95% of my rattle. It was the black wind deflector trim piece on the sides of the rear glass. There is a tab that's apparently supposed to have tape on it. Ugh 60,000 miles of rattling fixed with a 1" piece of 3M VHB tape. My car is pretty much silent inside now (aside from the intake and subtle rumble from the racing beat muffler. IM CURED!
Something under the painted trim piece is still rattling if I tap on the panel. But, I can't hear it while driving, so I don't care.
Upvote 0
