Cutie Needs N20 Help!!!
Mazda5Chic04
1998 VW Jetta Turbo Diesel
Haha! New that got your attention! Alright guys, I'm doing a science fair project on the effects of N2O and gas combustion engines. I also need to talk to some people who have blown their engines with N2O...pictures help too! Any help ya'll can give me is greatly appreciated!
Thanks guys!!!
~*~Mo~*~
what kind of stuff do you want to know about? the whole process in general, whats going on specifically or what? as to blown engines from N2O, I don't know if you'll find too many people on this forum who have pics of their own engines since everyone here is pretty intellegent and don't just throw a bottle and hit the fun button... but I'm sure people can dig some pics of other rides with blown engines...
but yeah... back to the point, what specifically are you lookin for?
I really just need to know about the blown engines...i need pics of anyone's car! Lol, Chandler (MP5Driva03) helped explain the basics of N2O to me, but anything you can tell me will help. This project is due Friday, and I really just need help doing it....damned science fair....but yeah any information about blowing the engines will help greatly, and any gen. knowledge about N2O helps too!
an engine blown on Nitrous doesn't lok any different than a N/A or Turbo motor, save for the obvious differences (visible turbo, or NO2 lines)
just find some pics of holes punched in oilpans, or broken rods.
also, there are several ways of "blowing" an engine:
broken rod = too much momentary torque from lean/ultra efficient combustion, or bad rod bolts. etc
broken piston = too much torque or ultra lean condition resulting in cutting torch like effect. etc.
it just goes on and on
How does nitrous oxide help an engine perform better?
This Question of the Day talks about how sodium chlorate acts as a way to store oxygen. You release the oxygen in sodium chlorate by heating it. It turns out that nitrous oxide (N20) works exactly the same way. When you heat nitrous oxide to about 570 degrees F (~300 C), it splits into oxygen and nitrogen. So the injection of nitrous oxide into an engine means that more oxygen is available during combustion. Because you have more oxygen, you can also inject more fuel, allowing the same engine to produce more power. Nitrous oxide is one of the simplest ways to provide a significant horsepower boost to any gasoline engine.
Nitrous oxide has another effect that improves performance even more. When it vaporizes, nitrous oxide provides a significant cooling effect on the intake air. When you reduce the intake air temperature, you increase the air's density, and this provides even more oxygen inside the cylinder.
The only problem with nitrous oxide is that it is fairly bulky, and the engine needs a lot of it. Like any gas, it takes up a fair amount of space even when compressed into a liquid. A 5-liter engine running at 4,000 rotations per minute (rpm) consumes about 10,000 liters of air every minute (compared to about 0.2 liters of gasoline), so it would take a tremendous amount of nitrous oxide to run a car continuously. Therefore, a car normally carries only a few minutes of nitrous oxide, and the driver uses it very selectively by pushing a button.
These links will help you learn more:
taken from howstuffworks.com
link:
http://auto.howstuffworks.com/question259.htm
Chas
Here is pictures of my 1st engine, and what happened at the hands of an ignorant use of N20. Not enough fuel:
Thanks guys!!!
~*~Mo~*~
Contact THE experts (the people who created NX):
http://www.mrnitrous.com/
So, you're a CUTIE huh?...(hitit2) (whitep5)
