custom made hard pipes with hks flange and hks gen 1 bov
ive had these in my closet for awhile and just found them after the christmas clean out of the house. the bov needs a new outer casing but will work for now. bov was working when i took it off the car 2 years ago with the pipes. asking 150 w/o shipping.
if you need more pictures pm me.
So I'm curious how you were running that setup. I see no BPV nipple, so it must be a relocated MAF setup, but the cold pipe is 1 piece? Where did you have the MAF? Also wondering what that stuff is inside the BOV.
wtf happened to that valve =O!
1.i think the stuff is the bov is fix-it-foam. 2. no relocated maf and the car ran fine just had the turkey noise. 3.yes the cold pipe is 1 piece so is the hot pipe.
it looks like the front of the bov the triangle piece got too hot and melted and the original owner used fix-it-foam to fix it. other than that the little pipe that is supose to be on the back is missing also. just trying to be as honest as i can. both things would be an easy fit. id just take out the triangle piece and call it good.
how am i supose to have receits when i bouth the car used and the pipes cam on the car?
its got the yellow hks on the top. its hard to see because the original owner did a bad job at painting it black.
no the guy who had it before me was a fat turd and i fixed alot of s*** he messed up but the car ran fine.
common guys i need to sell this thing to get a dyno tune on my stand alone!
