Clutch adjustment
t3ase
Banned
Contributor
Is there anyway to adjust the clutch so that it doesn't travel all of the way down to the floor? I drove a friend's stock Eclipse Spyder and on his car, the clutch pedal doesn't get anywhere near the floor.
Yaw, I heard that'll work wonders on the feel of it. I was hoping there was a spring or srew that was adjustable..
there should be something to adjust somewhere along the way, but i've never looked at it to see where it was. on my laser there was a threaded screw on the back of the master cylinder inside the car up under the dash that you could adjust, so maybe try there? just follow the brackets/cables/lines coming from the clutch pedal until you find something to adjust, cause there should be something that can be adjusted.
