Changing MSP stock fog light bulb
No.5
..has anybody swaped out these bulbs yet? (for those that may do so). If so, what bolts did you remove underneath the front air-dam in order to remove the light from it's housing?
(from memory here)
When I got underneath to aim mine, there were two screws/bolts through the cover on each side that I had to remove, then I was able to just pry the plastic cover away without removing it.
You have complete access to the foglight mounts then.
