Carbon Fiber Hood Help
vIZIon4
'03.5 MSP Titanium & '00 S2000 GP White
is there any way i can fix this?
MarkSpark said:
put a CF sticker over it? I'm no kidding
Screw that, the sticker won't last on there very long if anything buy real cf sheets and cut one out and paste it there they are made out of real cf not the vinly crap that will off set how the hood looks. You can purcahse cf sheets here at www.carper4mance.com
Do not put a damn sticker on it. Doesn't that sound like a freakin bandaid to you, literally? This is what you do need to do. Get that sealed up quick! If water penetrated the lay up it may delaminate the hood and you'll get a bubble instead of a scrape you have 1 option as far as I'm concerned in order to seal that up
Go to a surf shop or someplace like it. They probably sell board repair resin which cures by UV light. In this stuff is fiberglass as well so it will be strong. It usually comes in a black bottle and looks like glue. Pour some on and rub it over it and let it cure. To save time sanding it down put some plastic over the resin so you can shape it with your fingers whilst letting the UV in to cure it
melicha8: Thanks for the great advice. ill do just that...
hood came like that in after shipping. i bought it from a member on this forum. im tryin to get some money back because of the damage to the hood.
