Bov with injen CAI
azian6er
Asian Law Student
Mazda Speed Protege #987
Just curious if this woud work.
Since the injen CAI is a hard pipe obviously, and is attached to the stock in line recirculating bypass valve, I was wondering if I could take off that line with the stock bypass valve and cap both ends where they previously attached to the black plastic hoses and weld into the Injen CAI a BOV of some sort; maybe even an HKS ssqv.
Would this work, or would I have trouble with stalling and such? I would weld in the flange for the bov after the flow meter before the entrance to the turbo.
What do you all think???
--Bryan
no, for the simple fact you need the BOV in the charge pipe line, preferably close to the throttle body. :D Look around at alot of the turboed cars, you will see the BOV is after the IC also. Its that way on your Speed as well. :D The BOv is there to prevent backpressure on the tubine, so it needs to AFTER the turbine.
Hope that helps bro. and good tuning. :D
aww s*** , there goes that idea........ So is it really worth it for this injen?? (serious question)
Let the flames begin:eek:
