Biltz dual TT install NEED HELP ASAP Vaccum hose running
Pkay
I'm using the common online install for this and its going great.... only thing is when running the vaccum hose through the rubber gromett under the windshield wiper motor...... how do i get the dash off to get to the hose once its run?????
dont wanna **** up my dash so if there are any other ways or if someone can explain this to me briefly it'd be appreciated
I don't think you want to do that. Some guy on here tried to take his dash off took him like all day it seems you have to take out the center console too. wish I could help you but I don't know
I didnt use that hole after all, I just drilled a new hole down by the steering column in that plastic. It's clear of obstructions and you can see/grab it without problems.
heres the deal.... that windshieldwiper motor is above the firewall IE have to get above the firwalll to get it.
cant grab it from the side once its ran through cant even see the wire.
thinking of using steering column.... we used that on our rx7.... only problem is our steering column on the MSP is low as **** and i can barely see it on the engine side.
this sucks we now have a surprise thunderstorm rolling in.... no rain in 45 days and mother nature surprises me the day im working on my car
figures
If you use the grommet I used and showed on my webpage, you can easily see and grab the hose as it comes through.
Britt
got it! was hung up on the firewall area .... the gromet is right above the firewall so if you pull the side left or right of it you can grab it.
its installed fully now and its lovely ;)
