I've been getting fairly often where the car almost dies - feels like ignition(?). ALWAYS only 30 seconds to a couple minutes after startup. It will almost die, unresponsive to throttle. Then in about 5 seconds runs fine again, for the rest of the trip. This can either be a stone-cold start or after sitting for only 15 minutes from running. The only thing I did recently is go to NGK long reach plugs - same heat range. I guess I could swap them out again to verify. The coils are recent like a year ago. I did also recently replace the idle air control valve, which seems to behave OK.
