StupidBabboon
- 2002 mazda protege5
I"am going to be starting a project for the winter and will be assembling the following parts to do a swap out of my automatic.
Transmission: id like to get a msp transmission but and mp5 will do
CLUTCH / FLYWHEEL:Clutch kit (clutch disk, pilot bearing, pressure plate, release bearing, clutch alignment tool)
Clutch release fork
ELECTRONICS :5 speed ECU,5 Speed Engine harness,5 speed starter harness,5 Speed Starter
AXLES:5 Speed driver and passenger axles with joint shaft
PEDALS:Clutch pedal,Brake pedal
MOTOR MOUNTS / BRACKETS:Transmission mount,Rear Motor Mount Bracket
SHIFTING MECHANISM:Linkage bars,Shifter,Shift knob and boot,
CYLINDERS:Clutch Master Cylinder with rubber hose + clutch master cylinder gasket,Clutch Slave Cylinder,Metal piping between two cylinders plus clutch line.
Clutch release fork
