Auto Meter A/F gauge Question
Heathen23
I don't see no ears
MS Protege and Mazdaspeed 3
With an Autometer Air Fuel Gauge does the MSP need a seperate 02 sensor kit or does the one that comes with the Autometer gauge work with our stock set-up?
There is a seperate 02 sensor kit availabe and I am unsure if this is necessary with our stock sensor.
Thank you to all that can help on this matter!
i think it hooks up to the stock one...check me on that. but do you really want a light show? cause that's about all the useful info it's gonna give you. just a heads up.
Thanks for the heads up. I'm familiar with the guage and it will accomplish what is necessary for this application so that is just fine and that is not the debate for the moment. Just wanted to make sure it was compliant with the stock o2 and different o2 sensor was/wasn't necessary!
Thanks again!
Need some help here!
question.
1) is our o2 sensor a 1,2 (non heated type) or a 3, or 4 wire(heated type)?
had mine Installed today, but it does nothing. it only blinks a little in the lowest lean mark only under hard acceleration, then goes blank at all other times... I think this guy hooked it up wrong...
nevermind... I checked the install, and the guy hooked it up to the orange wire insted of the blue/pink one... moron...
