Any CX-90 Owners do their own maintenance yet?
2007 Mazda CX-9 Touring
I was wondering if anyone has done an oil change or other diy regular maintenance on their CX-90 yet…If so, please do tell, thanks!
I'm going to rephrase this question. Has anyone here done any type of diy maintenance on their CX-90 yet?
Yes, oil and filter change.
Apart from the need to remove the access panel, everything is very easy. The oil filter is completely vertical, so it is easy to prefill without spilling. I would suggest buying a supply of crush washers. After completely draining, mine took about four and a half quarts of oil. The manual says 4.8.
MHEV INLINE 6. The inline six has the oil filter horizontal. Relatively easy oil change. Open hood and raise engine cover. Secure to bottom of hood with clip on strap attached to the bottom of the engine cover. Break loose oil fill cap. Remove bottom access cover. Cover cross member below oil filter. I wrapped a plastic bag around it. Break loose oil filter and let it drain. Will be messy.
You will need the oil filter wrench for that size filter. There is no room to get a strap wrench or jaw type wrench to grip the filter. Remove old filter and replace. Use OEM filter. They are not expensive. I bought mine on Amazon. Non OEM filters tend to leak since most have a flat O ring. Pull drain plug and drain crank case. You will get 6 and a half quarts out. Replace drain plug with new crush washer. Put access cover back on. Replace oil with 0W20 or 5W30. Fill to top of dip stick. Start engine and run for 1 minute then shut off. Recheck oil level and top off if needed. Replace engine cover and close the hood and you are good to go.
For info here is a video. The type of oil is dealt with at about 30:00 into the video but I suggest you watch the whole video.
Just changed my 2025 CX-70 oil again (should be same as CX-90. Have to say it is a major PITA because of the location of the oil pan. You can't do it properly without putting the entire vehicle up on jackstands. Couple of suggestions for a mess-free change. I use a small plastic container to collect oil (about 14"x16"x6"), which afterwards I empty into a cat litter container using a funnel, so trying to get everything in the container without making a mess can be challenging, especially when you're on your back with little clearance above you. My recommendation is to loosen the oil filter first (you should always do that anyways, just to be sure you can get it off before draining the oil), and just loosen it enough to create a flow of oil into the container. It will take longer, but it won't hit the crossmember. Don't try to remove it completely when the oil is finished draining (there is still oil in the filter). Just unscrew it until it is loose from the end, and tip the back of it up to allow more oil to drain. You should be able to empty the filter enough to be able to remove it without losing any oil, then drain the rest over the container. Second, before you remove the drain plug, go get a plastic sandwich bag and duck tape along the short edge of it, leaving about 3/4 duck tape exposed. Tape it securely to the oil pan above the drain plug. Instead of the oil shooting out and missing the container, it will hit the plastic bag and pretty much drain straight down into your container.
Oh, and one clarification from RobertJT's excellent post. I believe when he said 'top of dipstick', he really meant that the oil should come up to the level of the 2nd hole from the end. If you go above that 2nd hole, you are overfilling it. Usually the difference between the first and second hole is 1 quart. I use that as a guide in how much to add when the level falls between the two holes.
Absolutely correct. I have since went to the Vevor oil extractor which saves a lot of the mess. I use it in conjunction with a 12V oil extraction pump. Still have to deal with the mess of the horizontally mounted oil filter and the inconveniently located dip stick. I did plug the top hole in the cross member that is in the way of the oil filter. before I did invariable the oil would runoff into the cross member where it then drips out the bottom hole onto the arm of the unlucky person in the process of removing the filter and then continues to drip after you have buttoned up the access plate leaving streaks of oil in the underside of the covers.
I am looking at a filter relocation kit so I don't have to jack up the car but the filter they are using is an odd size and has a special regulator built into it making finding a generic kit difficult. I want to continue using the OEM filter. I will periodically drain the oil with the drain plug so as to get the bottom sludge out , like once a year. Invariably with the car jacked up using the drain plug up in my driveway a wind comes along and blows the oil stream in my face.
I think they put this engine in backwards from how it was intended based on the dipstick, timing chain and drain plug locations. I heard you have to pull the engine to change the starter.
📦 Need Mazda Maintenance Parts?
Popular Mazda parts from the Mazdas247 Amazon Store!
→ Shop the Store
