So I know it is not just my car, as many have mentioned this rough spot in the rev range. I have inserts on all four mounts and I am tired of the vibration when the car kicks into high idle from either the fans or A/C. In the summer, I often just keep my right foot slightly on the gas to keep it over 1k, but this is a truly awful. I am tempted to just remove the inserts, but I don't want a sloppy engine either. The car is actually very smooth at any other RPM. It's not a V6, but acceptable.
So I've always thought it must just be a harmonic frequency of the FS-DE and there is nothing we can do about it. I've read having the crank balanced helps, but I am not planning on investing the kind of money needed to do that. Maybe if I blow this engine, and need to build up a new one, (although in that case, I'd rather build up a KL instead).
But when I got my car running again last week and the PCM was once again learning how to idle the car, I noticed it vibrated at lower rpms as well, very similar to the normal high idle vibration, and I began wondering if the 800-900 vibration is actually a tuning issue. I know our car is tuned like garbage from the factory, maybe this is also due to tuning.
I am thinking the vibration could also be caused by the VTCS, but I think there are enough people now who have removed the VTCS to know if it causes the vibration to go away. If anyone who has removed it would comment on the affect on the vibration, that would be appreciated.
I should have my megasquirt running the car in the next few weeks depending on how much free time I get. I know tuning for idle is difficult. My plan with the MS was just to make my high idle 1100rpms to relieve my right foot, but if I could get rid of the vibration altogether, that would be even better.
