6 1/2's in a DX?
low_psi
Contributor
ms|slowtege #399
from what i understand i can fit 6.5's in the front doors of a dx. correct me if i'm wrong. i'm trying to salvage as much from my mx3 as i can...
I'd assume a protege dx, and a newer one at that?
A 6 1/2 can indeed fit but it takes a little modification. You'll need a 1/2 spacer ring. Also you need to trim the ring on the back of the door panel. Any good stereo shop should be able to manage the task for around $60.
thanks. not a civic but a protege dx...
i'm gonna do all the work myself, i just wanted to be sure that the hole in the door was large enough. i'll worry about depth clearance later;)
the hole isn't big enough. The space takes care of that though.
not a problem. thanks for the help! the rear of the sedans use 5x7 or 6x9's correct?
6x8 and 5x7 are paracticly the same thing so if you come across some 6x8s and aren't sure if the'll fit, don't worry they will.
