The radio in my 01 dx was conked out when I bought it, so I threw in an old POS cdplayer I had laying around. Wiring the HU up to a metra harness was super easy and at the time I figured it was as simple as that. I just purchased an inexpensive Boss all digital (no cdplayer) HU that puts out 4x50w. I plan on purchasing some inexpensive speakers for the car next and I started thinking about the implications of wiring. The HU outputs are the basic +/- FR FL RR RL setup. Are the 4 speakers in the door-panels wired in parallel (ie. sharing the FR output to both passenger side door speakers) with the 6x9 shelf speakers running on the RR and RL outputs? Or do the 6x9 and rear door panel speakers share the RR and RL? Obviously the split wiring is already in place because as far as I can tell all 6 speakers are getting power and an audio signal from the 4 outs. When I get the car back from the shop I will try and isolate which speakers are running on which signals by using the fade/bal functions on the HU. The only reason I am concerned about this shenanigans is because I want to buy speakers that are the proper spec for a 4x50w signal split up between 6 speakers. I'm not against installing a small amp to power the rear 6x9's for a little extra bass and loudness, which would leave the HU outputs powering the 4 door speakers, but I wont bother if I have to run a new wiring setup to do it. If anyone has tackled this before please chime in, I'm a stereo n00b so be gentle
Thanks
