It's taking me a while to install the reverse camera on my 5, but I'm going to post ongoing note here before I forget things. Hopefully later (like, when I'm not at work) I'll post pictures too.
So, I'm installing a rearview camera, if you can't tell from the subject of this post.
Parts I'm using are the Gentex autodimming rearview mirror with 3.5" monitor built into it, and the "Mercedes camera." I got both of these from visorview.
The first thing to note is that the Gentex mirror is about an inch wider than the stock mirror on my 2012 Mazda5. That's not so bad, I just see more of the D-pillars.
Here are the two mirrors side by side:
The disappointing thing is that the Gentex mirror actually sticks down lower than the stock mirror. This is because the ball joint sticks pretty much straight back from the windshield mount vs. the stock unit which sticks up more- this allows the connecting arm to be rotated higher towards the ceiling. This isn't much of a problem since the roof is pretty high on the Mazda5, but I usually like my rearview mirror almost scraping the head liner.
Here's the stock mirror:
And here's the new one:
The second thing to note is the stock mirror removal. Damn, it was hard. I read all the instructions where you stick a small flathead screwdriver up the slot and twist to release the retaining pin. No, there's no retaining pin- it's a wide, piece of spring steel that's wedging itself onto the mounting "button." I was using a way to small screwdriver and actually getting it past the side of the spring steel, doing absolutely no good. Aim the screwdriver towards the center of the mount to get between the spring steel and the button and then slide the mirror up. Really, a better picture will help. Maybe my problem was trying to look at the pictures on a phone.
This is what the back of the mirror mount looks like:
Oh, BTW: click on the pictures for bigger versions.
You can see on the upper left side where my screwdriver was scraping the metal mount after sliding past the thin piece of spring steel in the center. Yeah, the spring steel looks like it did get scarped up a little bit on the corner, but I guess I needed to push more towards the center.
So, this is taking a while since I'm being meticulous.
The first stage was getting the mirror replaced and wired up. I ran the wires down to the passenger side since I figured there was a fusebox there to pull power from. Since I have a Touring model, I pulled power off the seat heater supply wire since I don't even have seat heaters (yet).
Since someone else here mentioned that they should have started at the back when installing their camera, I decided to start with the camera and wire to the front of the car. Snapping all the panels off the hatch wasn't that big of a deal, but I was a bit to hasty in taking off the trim piece that the license plate lights, trunk release, and eventually the camera would be mounted to.
There are six nuts and three clips holding that piece on, but you need to remove the reverse light lenses first (one nut each) and pull that trim piece diagonally downwards in line with the bolts. Me, I broke a few of the bolt mounts and one of the snap clips by being a bit forceful and not removing the lenses. Hopefully my epoxy holds.
Here's the inside of the trunk/liftgate showing the six retaining nuts circled in red, but not the three snaps:
The plate light trim piece has what looks like bosses on one side for mounting a future camera. What I had didn't fit that bolt pattern, but I decided to place the camera in that approximate location. Why are reverse cameras mounted on the left hand side of cars when if you're parallel parking you want to see the right hand side? Anyway, I mounted it on the left hand side since that's where the mounting bolts were which I didn't use anyway.
Here's the whole trim piece/handle:
Here's a closeup on what I assume are the OEM camera mounting bosses:
And here's my camera installed. from the inside:
And from the outside:
Continued in the next post...
