2009 Mazda5 Gran Touring AC Help
tefloncandi
2009 Mazda5
My air conditioner just stopped working! The cabin fan still operates, the fan in the engine bay comes on, but the compressor will not kick in! I checked all of the fuses and they are OK. Any ideas?
Checked the under hood fuses? The compressor will use way too much electricty to trust with a basic 15 or 20 amp fuse.
Check the refrigerant pressures. If they are too low, the compressor won't engage. The high and low side equalize when the compressor is off, so they should be 80+ PSI when the system is at rest. If you can get under the vehicle, detach the compressor clutch wire harness. Test the vehicle side with a test light or multimeter (with vehicle running and a/c mode selected). If voltage is present, then check the compressor side by connecting battery power to it's harness wire and see if compressor engages. Report back your results.
EDIT: Just saw your description that the radiator fan turns on when the a/c is selected. Sounds to me like the compressor clutch may be the culprit, but you can still do some investigating. Otherwise your vehicle is still under full warranty.
