2000 Protege - Turbo - $1800
More pictures at https://picasaweb.google.com/114059419102775323714/Protege?authuser=0&feat=directlink
2000 Protege ES
All of the following are swapped from 2003 MSProtege:
Complete motor and ECU
5 speed trans
Shifter
Front Brakes
Front Swaybar
Motor and all swapped parts has 68k miles on it. Shell has more, maybe 160k. Rear end is still 4 lug, drum brakes from OEM. I drove it around like this for 5 years, with two spares in the trunk in case of a flat, one for each end of the car. I didn't do the swap, just got the car past emissions and fixed little things, kept up on maintenance.
Car runs great, shifts great, has good compression and strong vacuum. I changed the trans/diff oil to Lucas synthetic about 15k miles ago.
This would make a perfect donor car.
Cosmetically: There's a dent in the passenger rear quarter panel, and the drivers fender by the headlight is goofed up. Interior is just OK shape, glovebox is missing.
Mechanically: To drive it it would need a new passenger control arm, front struts, tires, an alignment, and possibly more. Car wasn't crashed, the dents are from a parking lot and are unrelated.
$1800 obo. Car is in Helena, Montana. Thanks!
List Date: 6/28/2013
For more info, click here to view the original listing: 2000 Protege - Turbo - $1800
Item Has Been Sold.
2000 Protege ES
5 speed trans
Shifter
Front Brakes
Front Swaybar
Item Has Been Sold.
