2000 626 intake manifold WITH 2002 EGR pipe NO VTCS
Status
Not open for further replies.
2001 BJFP MT
2016 BMYFS AT
Here's a 626 intake manifold off a 2000 motor... it comes with everything you see in the pics... fuel rail (for perfect fitment, no need to use your stock fuel rail and have it flopping around), 2002 626 EGR pipe (allows perfect fitment to the stock exhaust manifold), vacuum hoses, 34psi (at idle) fuel pressure regulator, 208cc 626 fuel injectors, PCV valve with hose, EGR valve mounting bolts, solenoid brackets, and throttle cable bracket
what's missing:
throttle body
EGR valve
vacuum solenoids
the intake manifold support bracket is the SAME as the protege one and is not necessary... I do not have it otherwise it's yours "free"
you all should know what this intake manifold does, so no need to explain
Practically ready to bolt into the car! No need to take off VTCS since it doesn't exist!
this came off a motor with around 120k miles on it and I took it off the motor myself (motor was bought complete for somebody else)
Don't miss this opportunity to buy a 626 intake manifold that fits perfectly into your Protege without needing to buy or modify parts to make it work! The included brackets and fuel rail are not usually found from other sellers here and those brackets lets you have a factory look!
asking $160 *shipped* to the US only by UPS
paypal only
PM me for paypal info
All sales final, no warranties whatsoever.
Tablet not included
Batteries not included
Some assembly required
attachment.php
attachment.php
Status
