1999 Protege front subframe
bvolks
99 Protege
While I was changing the front control arm this morning I came across some major rust on the subframe. I'm going to try to weld a patch on it but if that doesn't work I'm going to be forced to change the whole subframe. Unfortunatelty there is no way to get at the nuts to spray them with penetrating oil or heat them with a torch so I'm afraid of breaking them off in the body when I try to remove them. Has anyone replaced the subframe and has any tips to make my life easier when I attempt it? The rest of the car is in perfect condition and I'd really hate to junk it over a rusty subframe.
All i can tell you is get a subframe from a 2001-2003 Mazda Protege It has another brace making it a lot stronger... Use heat and a big pry bar...
