+15 offset, too much?
tehpeach
2012 Mazda 2 Sport 5MT - True Red
I got a lead on a set of 15x7 TSW's that are +15 offset, for CHEAP. Would I be poking like crazy with that kind of offset?
Yes they will like crazy. I just installed some +20 Offset wheels. They poke about half an inch in the fronts. Still look good though. Might do a bit of a camber adjustment. Fits fine in the back however. I'm running 5mm spacers and they were rubbing so i had to roll the rear fenders.
I would not touch a +15 offset wheel if I were you. ;)
Get some negative camber and you should be able to run them. You may want to stretch a tire to do it though.
If you can get it to work it will look awesome.
Very pokey! If it works it will look aggresive.
I'm running stupid low, which I don't know if the OP will get close to my height, but with 15x7 +36 with 205/50/15, I rub hard on full lock-to-lock turning. Ask my fenders.. they won't tell you, they'll show you the hurt they were taking.
Slap some camber on the fronts, run stock tire sizing, or narrow 195/50's to get some stretch on them.
