13b Miata gets FMC of the month
Hey,
If you can say it, how much is it for that kit ? (With engine included) approximately. I got a '91 BRG Miata and it's my dream to do the same thing as you ! Another question, do you know if the 13b twin turbo fits into a miata ?
SICK RIDE
-Max
The kit from mazsport.net is $3900.00 that has most of the main componets but you still have to get a motor. If you want to drop off your car and have him do everything it should be around 17 to 18 k. This is also doing the complete drive train swap to rx-7. you can put the motor on the miata transmission but this will limit the HP(about 250WHP).
As far as the 13b rew motor goes, the motor is the same size but the turbos would be the hard thing to fit. The picture below showes how close the clearance is on my 13bt. You would half to build some sort of custom exhaust manifold to move the turbos up on top. I'm sure it could be done but it would cost. Hope that helps.
Steve
