Spooled said:I really wish you had a datalog of the EGTs. That would really help right now.
ddogg777 said:Is your car equipped with ABS? Can a tranny with a speedo gear break at the diff and still give a speedo reading?
TurfBurn said:and contrary to popular belief.. they go DOWN during detonation.
TurfBurn said:I think people should spend the 500 bucks and buy JandS Safeguard systems(and no I don't sell them...)
It definitely sounds like a misfire to me, however it does not sound like a RICH misfire. But i'll have to listen to it again to be sure.TurfBurn said:So it sounding like misfire/richness to me is not insane... since I have never heard detonation outside of a car... so that makes me feel less like a dunce!![]()
Kooldino said:It definitely sounds like a misfire to me, however it does not sound like a RICH misfire. But i'll have to listen to it again to be sure.
-9 dam man i have -13 up top at 11 psiBigg Tim said:So were you ever able to watch the datalog? If not, post it up so we can check it out. Definatly ruled out the rev limiter and over rev's with that video, 6-6500 MAX. I'm thinking maybe you didn't have enough timing out. You were puling only 9 degree's up that high, what kind of timing have other MSP's pulled at that boost level.............Focus???
It does seem wierd that #1 is so bad, but the others are pretty clean. Wouldn't all the pistons have a lot of detanation if it were detonating THAT bad? Kinda makes you think the detonation wasn't the only thing. Did that chunk of metal come out of #1? Maybe that caused all the damage to the piston?
mazdaspeed75 said:-9 dam man i have -13 up top at 11 psi
so i figure iam pulling about right for my setup Plugs looked good as of yesterday . I am running 11 psi and pulling like a beast i turn down the boost slightly to try and get the a/f alitlle lower to 12 or soTurfBurn said:Usually you figure 1 to 1.5 degrees per psi on these motors.
well inkow from the get go the timming was a big issue to me i never could get a answer on how much. I figure now that everyone is different on setups and i really think i was detonating when i dynoed and only had like -7 out at 9 psi so we pulled more but i though we had to much out so i turn up the boost every couple of weeks and listen and watched how she ran. 11psi and -13 from about 4500rpms and up seems a good spot for the hot humid weather here and i still make real good power I am not sure if i will redyno now with this happening to you . I really think i am at 230 whp plus I pull so hard thru all gears I almost spin in 3rd .BlkZoomZoom said:I guess that would have been a good question to ask like 3weeks ago. lol.
I heard we need to be like 20 degress adavnced under boost and Jdm sam tuned a car and found it to be like 23 24 degrees under boost and he said that was to much so man i not sure I think for me it seems pretty good the white on the grounding strap seems to have stayed th esame so i guess my egt are okBlkZoomZoom said:I guess that would have been a good question to ask like 3weeks ago. lol.
You mean 1-1.5 degrees per psi past the stock boost level? I always thought the timing curve was pretty conservative as it was on the MSP.
