Zoom Zoom boom potential partout thread.
Status
Not open for further replies.
stevew145
Mazda Protege ES
I'm gauging interest in my zoom zoom parts, considering my engine has 2 holes in it and is not going to zoom anywhere any time soon. On the way to work this morning I blew the engine in spectacular fashion. Full throttle, 12 psi, 6000 rpm boom, rattle rattle smoke. Looking at getting an MS3, need a down payment!
Open to offers, keep it reasonable!
Lets get started...
-factory GT2554R with about 65k miles on it. No oil leaks or shaft play.
-custom and factory oil lines. Custom lines are all braided stainless with a -10AN return welded into a new basepan, cost me a small fortune but it was perfect for an easy conversion.
-Factory manifold. No cracks, but I think one is starting.
-Turbolife FMIC blow through MAF with turboxs bov.
-ssafc v2
-GHL 3" Downpipe
-Injen CAI with K&N filter and brand new cleaning supplies
-SLS solid front mount
-MSP ECU
-Forcefed column gauge pod
-Minerva (ebay company, 70 durometer, great quality) rear mount 2000 kms,
-exedy stage 1 clutch 2000kms flywheel was machined before installation.
-440cc wrx injectors
-22mm Progress rear sway bar,
-Forcefed Column pod
-TWM Shifter and bushings
I am considering selling my carputer aswell. It is my pride and joy. Full integration, OBD2 scanner through bluetooth, genuine centrafuse auto, not a cracked version so you can use bluetooth for handsfree phone, obd2. everything has auto on and off with the ignition, screen turns on and off aswell. power switch that is almost like factory quality near dimmer/fog light switch. 7" touch screen only about 2 months old. Perfect for tuning and monitoring as it is right in front of you and doesn't slide around. screen fits in dash like a double din dvd player, computer mounts on rear seat like an amp, and is about the same size. Custom wiring harness is basically plug and play into your fuse box via fuse splitters. You need to relocate cd player to glove box, but everything reaches and if you have a cd player with aux in you are set! I would like to sell it but I don't want to be 24/7 customer support. This is not a regular desktop computer, and requires a in depth knowledge of a computer. Everything was bought from www.mo-co-so.com. This computer has cost me a fortune and I don't want low ball offers.
I can and will get pics if I am going to go ahead and sell it all.
Status
