Are roads here are good in some places and horrible in others. Its really not that bad. Its easy to adjust too, just play around with it till you find whats most comfortable. In the rears i just remove the top plastic trim and pull the carpeted sides out far enough to get your arm in there. I use an allen key too, rather than that little tool.
The spring rate is soft enough to compensate for a stiffer damper adjustment. Plus the stiffest setup on these isnt crazy rough IMO as well. Good luck. im subbin for your final adjustments.
