ok guys, havent been around in a loonnnngggg time, but here it is.
trying to cater to locals first because it will be a b**** to ship most of this stuff. so for shipping, the more you buy, the better the deal. if you want a bunch of small insignificant things then i will just charge you for a "box" and basically whatever i can fit in the box goes. shipping is NOT included and buyer pays paypal charges
so the yellow car is going. getting stripped down to the bare minimum and then either sold or scrapped. its a shame with all the work i put into it, but its been sitting here for almost 5 years now doing nothing. its time to go.
if there is anything you can think of that you might want just ask. be patient because i will be getting a lot of PMs and will take a bit to respond, but i will try my best to do so in a timely manor.
the car is has no hood, trunk, bbk or engine (turbo kit). they have been sold. but the remaining body pieces are there. interior is almost complete, other then seats and head unit. paint was is MINT on body. car only has 58k KMS on it.
pics of yellow car and spicy (just for the wheels)
a couple things that i can think of that are extra pieces are:
Authentic Buddyclub2 kit
Custom rear bumper with cf inlay, amazing shape and fit and freshest paint. Front bumper has been cut for a custom I/C project that was never completed. Sides are in great shape bu need paint. Normal road wear has worn it away near the wheels.
Rear $300
Sides $150
Front $80
Vibrant FMIC Core - $100
forget the specs, ill measure and get back to you
BBS RG-R $1800
Forged lightweight! Custom finished in high gloss white. Mint!
17x8 +38 wrapped in brand new Yokohama S.Drives 195/40/17
perfect flush setup for the protege with no rubbing issues
15mm spacers - $180
Bolt on spacers with studs built in, hubcentric
Added these to the BBS for a slight Poked stance.
GHL 3" Exhaust - $300
this is the Turbo back they offer but it is missing the downpipe. the midpipe has been slightly altered and has a female slip fitting to connect to a downpipe. you will have to modify your downpipe or this pipe to mate up. the tip has been shortened roughly 3-4" for a flush fit with the buddlyclub rear bumper. this also would work perfect on a P5 rear section.
MSP LSD - $300
perfect shape. bought to weld it and install for the spicy but replaced it with a full spare msp tranny i had laying around.
AWR Race Rad - $180
All aluminum, full length. Needs a quick spot weld on a tube to hold fluid. Also has no bottom outlet or mounting tabs. A competent welder or shop can fix it up for under $100 easily.
Mazdaspeed ECU - $180
Title explains all
Custom dual gauge pod - $150
Two 52mm gauges mount in the corner of your gauge cluster surround. Small crack around one gauge. barely noticeable or easily fixed
Greddy catch cans
Radiator overflow and oil catch can. Good shape. Might need a quick buff to bring back it's original shine
Each $60
Both $100
AWR rear sway bar - $60
Missing brackets and bushings.
so i also have a full out race shell. just needs a drivetrain. (but sitting on stock msp suspension right now) - $2500
Rolling chassis. Full roll cage. Tube frame front end. DGMotorsports one piece fg widebodied front end. DGM full cf dash. Momo carbon kevlar race seat and harness. Suede Momo race wheel and quick release hub. Acid dipped frame, fiberglass panels and lexans windows. Great project!
Rear $300
Sides $150
Front $80
BBS RG-R $1800
15mm spacers - $180
MSP LSD - $300
AWR Race Rad - $180
Title explains all
Greddy catch cans
Each $60
Both $100
