YAY P and V codes
LV Tunerz
07 MS6 GT
P0134 , P0102 , P0113 , P2004 ( it says stuck open what does that mean ??? ) , V0121
thanks for your time !
well the first one is for O2 sensor, 2nd one is for maf sensor, 3rd one is for iat sensor and not sure about hte others. do you have all these things plugged in?
check your fuses and everything as well. sounds like you have an electrical problem.
ya i got the codes in words now and here they are !!!
1) Lost Commenication with IPC
2) Mass Airflow circuit low input
3) Intake Air Temp sensor 1 circuit high input
4) Intake Manifold runner control stuck open bank 1
5) Lost Communication with ABS control module
6) O2 circuit No Acyivity detected
Theres the codes in english , still think is a electrical problem ???
Man, that's a lot of different codes ... are you sure the ECU is hooked up properly? Maybe it's fried??
well i just talked to this female here in denver that works on high output turbo cars and she said those code are also from getting to much air and not enough fuel that would produce to little exhaust
