WTB: stock wastegate
Status
Not open for further replies.
you can buy a new one from the dealer too if you want... retails for $300 (but I'm sure you can get it cheaper than that)... it IS an adjustable wastegate so you can actually set your boost!
part number is 0000-88-C96A
part # ATP-WGT-011B
6 PSI means thats the boost it is set for, its the same as the stock wastegate & you can still raise your boost pressure...
Pick up the ATP one velocifero just put one on his car this weekend cured his waste gate problems and eliminates the mazda part from going bad again
Status
