WTB: OE sized radiator
Looking for a radiator. Has to be the short rad due to the route of the hard pipes.
Can be stock or aftermarket. Hopefully stock as I do not want to spend a lot.
Let me know....
i have one. but heres the deal. i thought it was cracked. pressure tested it and it was fine, but once the car was on it would leak. i replaced it with a oem 300$ mazda one. the kicker is it turns out my thermostat was stuck open so the coolant was just boiling out.. anyway i can check it now for leaks since its out of the car? i wouldnt feel comfortable selling it unless im 100% sure its fine
That would cause it to run cooler then stock, you mean stuck closed.
You should be able to get a rad cheap through radiator.com. I have used them before, always comes like 1 day later.
MSP radiators are REALLY hard to source. Unfortunately, the only place I could find one was at protegegarage.com but it took 3 weeks for it to get here so I don't recommend it. The only other real option you have is to try your local Mazda dealership. Good luck.
i wonder if theres any other radiator we could use besides the sedan one that would be require minimal modding. $300 for a radiator doesnt sound too good
you can import a radiator for an RF-TDi from europe. they sell replacements on ebay for about $200 shipped (if i recall) but again, you have to play the waiting game.
