WTB.Mazda speed parts.
i have
msp ecu
side mount intercooler
gauge pillar
a/f gauge
turbo with manifold, downpipe and all lines
turbo timer
i need
boost gauge that is around 30$
universal pipe-40$ or cheaper
bov that is 6-8psi spring. 50$
couplers-10-15$
need a clutch for the near future- not to expensive
boost controller- ????
Shoot me a nice pm if you have anything. Thanks.
I have a boost gauge for sale... check the link in my sig and let me know if it's what you're looking for.
Boost controller, or change out the wastegate actuator (I believe the ATP WGA holds at 8psi). That is, if you're going to a more or less stock MSP setup. Otherwise if you're doing some custom-ish work, then yes you can run an external wastegate, in which case you can change the boost setting by changing the spring.
I've got a brand new Exedy stage 1 clutch and fidanza light weight flywheel both still in the box unopened. PM me if you're interested and I can give you a package deal.
