03spicyspeed
- msp#1648
I know its been talked about but i cant find eny info so. Can i put the 440s in my car and run them or do i need like a afc thanks.Oh and will the 02 03 wrx injectors work
Huh? I'll be throwing the injectors on .. as in, having them installed.^^ throwing in or out RUSH ??
my car was running very lean with close to the same mods when I had it tuned. the guy tuning my car said he couldnt believe my block was still intact. I was also at 15 psi though. I now have 720 injectors but that was only because I couldnt find any injecters that were smaller and could be overnighted
According to the research I've done, as long as you're running the stock MSP turbo, anything bigger than 440's is pretty much pointless.^^Rush i though you were upgrading bigger then 440''s which i was looking for but lmk how they'll work for you.
