1338 said:what fuel pump should i get
i guessing i need a FPR aslo.
1338 said:can i use the WRX 440's with the stock MSP ECU? i am planning on getting the MPI tuner. in a few weeks to a month from now. will the 440'a work till then.?
wait you ran wrx injectors on the stock ecu and nothing else at all?DiscreetSpeed said:i had them on my car before i got the engine management and it ran fine. now with engine management its the same just smoother entrance of boost.
read my previous post. after the build up thats what i slapped on before the ems came in.azian6er said:wait you ran wrx injectors on the stock ecu and nothing else at all?
was idle bad as hell? what about cruising?
-B
DiscreetSpeed said:read my previous post. after the build up thats what i slapped on before the ems came in.
then again i did have a prep'd head, p&p intake manifold, tb, and not to mention the redone exhaust manifold and turbo and exhaust....(glare)
yes sir...boost before the ems was about .4 bar.azian6er said:interesting. so the car ran fine as in the idle was ok and everything? how much boost did you run with just the injectors?
-Bryan
DiscreetSpeed said:yes sir...boost before the ems was about .4 bar.
