Would you do this?
TheGut
I was thinking about putting this in my car. What you guys think?
Which one you guys think?
The factory seats are fine with me. I would spend the money on alot of other things before seats. Only after I have done ALL the performance mods would I go with new seats and only for the weight savings.
tiny bit. but no seriously, u can spend your money elsewhere. the only reason I ever put seats in any of my cars was because well one was a drag car and one was for autox and i like to feel safe. if you want to be a little jdm get the autoexe shift knob...
tenzos are def not jdm. you wanna go with the Brides. but once again plan on spendin some serious cake thats probably not worth it. but if you've got most of the things done that you want it'll def give you baller status if you got bride seats.
its all up to you about hwat you want, but when you take the car to a track, one with turns not the straight ones, you will realize that there is no NEED for new ones.
if they save you atleast 30 pounds combined between the two, i'd say do it, plus you can save your stock seats from getting destroyed
dont get those seats, if your gonna get seats get quality ones that havebeen crash tested. Tenzo R just makes cheap knock offs of everything.
IDk bout seats, b/c if you got those, you'd probably also use a 4point seatbelt. And if i remember correctly, the 3 point seatbelt is design to allow the driver to fall inwards if the car rolls since there is no roll cage to hold the roof up like in a race car using 4 point harnesses.
And there are better looking seats out there that fit the design of the car better.
I had a set of Tenzo R in my Widebody Toyota MR2 Turbo show car (the one on my avatar) and they felt fine and worked great, don't hack it cuz its not recaro or sparco.... not EVERYONE can blow $1500+ on a pair of seats. Here is a picture of the ones I had in my MR2, they were very comfortable and worked great! Regardless of them NJOT being some big expensive seat, I still won multiple Best of Show Trophies with the car, so people still show love for stuff even tho its not expensive.
