THE FOG LIGHT RELAY IS LOCATED ABOVE THE CLUTCH PEDAL. YOU WILL HEAR A CLICKING NOISE WHEN THE FOG LIGHTS ARE TURNED ON. IT PROBABLY IS A NEGATIVE TRIGGER AND WILL HAVE TO BE OPERATED FROM A SWITCH. I HAVE CONSIDERED THIS BUT HAVE NOT DONE IT YET. I AM MECP CERTIFIED FOR ELECTRONICS AND HAVE INSTALLED EVERYTHING ON MY CAR INCLUDING THE ALARM. WHEN I ATTEMPT THIS I WILL POST HOW TO DO IT.
OK......I FIGURED OUT HOW TO DO IT BUT IT IS NOT EXACTLY SIMPLE. IT REQUIRES JUMPING A PARKING LIGHT WIRE (GREEN W/ BLACK STRIPE) ABOVE THE FUSE BOX OVER TO A RED WIRE WHICH COMES OUT OF THE FOG LIGHT RELAY. IT IS POSITVE TRIGGER BUT REQUIRES 2 DIODES TO BE PUT IN LINE SO THAT IT DOES NOT BACK FEED INTO THE HEADLIGHTS. DOING IT THIS WAY WILL MAKE THE FOG LIGHTS TURNOFF WITH THE PARKING LIGHTS BUT WILL TURN OFF WITH THE HIGH BEAMS ON, WHICH IS ILLEGAL IN MOST STATES.THE COOL THING IS THAT YOU CAN RUN THE FOG LIGHTS WITH THE PARKING LIGHTS AND IT LOOKS REALLY AWESOME. ESPECIALLY WHEN DRIVING DURING TWILIGHT. IF YOU WANT MORE INFO, LET ME KNOW AND MAYBE I CAN FAX A DIAGRAM TO YOU.
