Winter Tire Air Pressure
30-32 in the snow. 36 or whatever is recommended on the sidewall for dry streets.
I did a web search on this topic a while ago, but no one specifically stated that lower pressure should be used for winter tires. So I just still set mine close to 35 psi a few weeks ago, when it was still warm. I figured that it will lose a few pound when it gets below freezing. By the way, mine tires are Michelin X-ICE, same size as yours, and they looked quite flat even at 35 psi (not more inflated compared to 20 psi).
I believe it mentions adding 3 psi to the placard pressure (should be in the manual) but I think this is to compensate for the temperature drop.
