windshield condensation
2016 MAZDA CX5 GT
hello
I have a problem with the outside of the windshield condensation, how am I suppose to enjoy my AC, when I put my wiper on it just makes it worse.
hello
Suggestions: Don't direct the cold air to the windshield - just use the inside facing vents. Change your wipers :-).
You can also the turn the temp up on the AC, if you have auto climate control, or turn the temp knob to the middle of the dial if you have manual AC. The windshield is condensing because it is colder than the air outside, once you warm the glass up a little it should clear on its own.
This was caused on my Buick by moisture collecting in the fan blower housing. The drain had become clogged.
Clearing the drain (coat hanger from under the car up into a rubber drain tube) opened the drain and evacuated up the excess moisture.
I don't know all the physics behind why the condensation was on the outside of the windshield vs. the inside... But it worked.
