M mischiefmaster5 Member May 22, 2007 #1 17x7's 5-100/114 bolt pattern +40 offset? Will these work on a protege5 or will they rub? Thank you
N njaremka Wiggity-Wack-O-Tack Contributor : 2012 Mini R55 May 22, 2007 #2 5-100/114 means that the wheels are pretty much univresal. protege5 uses 5-114 bolt pattern. the offset seems a little low.
A aMaff High Speed Low Drag : 1992 Miata / 2003 Pathfinder May 22, 2007 #3 offset seems VERY low. I've got 17x7 +42s and w/ 215/45s they rub a little. I need to roll muh fenders
