will the boost..
fr0st
2003.5 yellow msp
go up by itself if i add a SMIC ? or do i need to get a more free flowing exaust for this to happen?
both of those together may give you a very small increase. like .5psi. I doubt the smic will change it hardly at all.
K,
i was asking since im looking to change plugs while doing my SMIC and wondered if i needed one step colder plugs..
Different plugs aren't necessary. I would look into a hi-flow or catless midpipe (most noticible power mod). Also I converted my Hiboost intake to CAI and it raised my boost by 1psi.
SMIC might give you a slight bump in boost pressure, but probably not much. however, you will feel less heatsoak with it. so that is a good thing.
I have one step colder plugs NGK PZFR7F-11... runs fine.
thats my next mod.. but it will go next spring.. gonna work too much this autumn to have time to do anything.
yea your boost will def go up, itll prob spike a lot higher also, or more frequent should i say
3" exhaust with dump closed, no cat, SMIC, Hardpipes and ATP wastegate I hit 9psi steady
with dump open I hit 9.5 then settle at 9psi steady
Again, your boost will not increase with the stock exhaust. the car will be faster and happier though. Exhaust is easy to change. Intake is easy too -- just get a filter and replace the airbox with it. you don't even need different piping. after that you will see your boost increase.
http://www.mazdas247.com/forum/showthread.php?t=123676839
Here is a GB on a FMIC kit, it is close to being over. Check it out and throw your name on the list if you're down.
i prefer a SMIC for my needs.. i'll never go over 10 psi anyways, and i live in a rather cold cold climat so heat soak is minimized to a very specific period of summer... like this morning it's 57 F outside lol
got the cone filter already.. it's fitted on the OEM intake pipe
next spring will be going catless.. the PG SMIC and the AWR mounts are my last mod for this year. :)
well done. you'll be happy with that, especially once you free up the exhaust. After that you're probably safe to run 7-8psi if it doesn't get turned up to that already.
what i wouldn't do to spank cars that im not supposed to.. ;)
